merging elements of array
I am new to programming.
I have a sensor that sends a data stream through a serial port. I have collect all that data in a 1D unsigned byte array. Now, lets say my 1-D array is [12][45][65][12]...... where each "[ ]"  is a element of the array. Now to make sense of this data what i need to do is merge two elements the array and multipy it by 2/(2^15). i.e. My converted data should by [1245]*2/(2^15). Basically 2 bytes together makes sense. I can do a simple add of each element. Also the other problem is,data from the sensor is a stored as the 1-D array  of unsigned byte. However, the converted data is supposed to be signed 16-bit integer.
Please give any suggestions on how to go about doing this.
Siddhant Shah
(4,603 Views)
I think there is a function that does specifically what you need. You can find it under programming -> numeric -> data manipulation -> join numbers or just search "join numbers". To get two elements you could use a for loop that is half the length of the array and take the current element and join it with the next.
(4,594 Views)
here is something you can play with
(4,588 Views)
Assuming you want big-endian byte order, all you need is typecast your U8 array to an U16 array as follows:
Message Edited by altenbach on 12-15-2008 06:20 PM
(4,580 Views)
Another option is "decimate&Join". (Here it is easy to change the byte order if needed).
Message Edited by altenbach on 12-15-2008 06:28 PM
(4,572 Views)
Thank you very much guys.
All this information is very helpful
(4,475 Views)
