DDS Waveform Generation Reference Design for LabVIEW FPGA
I recently reviewed the DDS example.  Looks good and I will be able to use it.  However, I think there is a problem with the reset accumulator code.  The reset acts on the next value of the accumulator and will therefore produce the current point using the previous value of the accumulator.  I have attached a suggested change.  The timing changes considering that the data flow changes slightly.
correctled files
Message Edited by stu@viewpointusa.com on 12-28-2008 06:10 PM
Stu
(3,736 Views)
sorry the VI FPGA DDS Generation Sine 1-ch v1.vi (44 KB) file is not the one I meant to post.   updated file refs in original post
Stu
Message Edited by stu@viewpointusa.com on 12-28-2008 06:11 PM
Stu
(3,733 Views)
