memory problem with producer consumer based architecture
 I have Prepared a data acquasation on producer consumer based archtitecture.In producer loop  I am acquiring all data and in consumer loop writing all data directly on  to the disk.But after some time my memory increse so fast while running.I am using 4 GB ram(pentium 4) on my pC and have to perform long time measurement.Even if I am not writing my data, my memory increase very fast.Please give me good suggestion for this problem.I have attached my LLB file.
Message 1 of 11
(4,171 Views)
down convert the VI to 2011
AB
Kudos are Accepted
Message 2 of 11
(4,135 Views)
I have conver it to 2011.If you have any suggestion for measurement over long period than please give me.
.After some time my vi ger slower and ram rapidly increase afterward.My pc(Pentium 4) with ram 4GB
Message 3 of 11
(4,124 Views)
In the attachment there are so many files,which is the vi causing problem
and how who running the code
AB
Kudos are Accepted
Message 4 of 11
(4,075 Views)
I am sorry for such inconvenience and late reply.My main vi is in  folder prufstand =>Test stand (second)=>prufstand 2.I am directly writing in my disc but still my ram increase rapidly.
Message 5 of 11
(4,062 Views)
hi
Here the attachment
Message 6 of 11
(4,061 Views)
block diagram of main vi
Message 7 of 11
(4,054 Views)
I think you have not updated the queue timeout ,so its better to define the timeout, may this may solve your issue,the default is -1,
and with this their should not be any waits in the code
AB
Kudos are Accepted
Message 8 of 11
(3,974 Views)
If the result file isn't found you'll never dequeue which'll fill the memory fast, is that what's happening?
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 11
(3,950 Views)
Thanks Bhramaji,
Should I use time out for both in producer and consumer loop?Actually I want to acquire  all time but saving file should bedone at defined interval.Is **bleep** possible with Queues?
Message 10 of 11
(3,932 Views)
