concatenating strings automatically for loop
Hi
Does anybody knows why does this doesn't work?
Thijs
Message 1 of 8
(12,340 Views)
I know this works:
But why not the other one, and is this operation time consuming for LabVIEW, it builds a new string every loop cycle....
Thijs
Message 2 of 8
(12,333 Views)
Accepted by topic author ThijsBoeree
Hi Thijs,
the error message of the broken wire is quite unique: "incompatible arrays connected"...
The help only mentions arrays to be connected by an output tunnel. Scalar strings aren't mentioned anywhere!
That's the "traditional" way:
Use ConcatStrings to concatenate an array of strings into a single string...
Message 3 of 8
(12,323 Views)
@ThijsBoeree wrote:
Hi
Strings are a bit funny with the concatinating tunnel.  LabVIEW concatanating tunnels only work on rectangular arrays.  An array of strings is really a 2D ragged array since each string is an array of U8s and each string has its own length.  Concatinating "On the fly" inside the loop tunnel then is no more effecient than building the string on a SR since a new buffer must be allocated for each iteration.  Use Gerd's snipette to concat outside the loop for best performance.
"Should be" isn't "Is" -Jay
Message 4 of 8
(12,305 Views)
Thank you so much!
It's clear now
Thijs
Message 5 of 8
(12,294 Views)
Not exactly. The array itself is a simple 1D array of pointers, where each pointer points to the relevant string - https://www.ni.com/docs/en-US/bundle/labview/page/how-labview-stores-data-in-memory.html
___________________
Try to take over the world!
Message 6 of 8
(12,265 Views)
Well,  I'll take my lumps and a bit of new knowledge. Thanks again Yair!
But, then why does the concat tunnel have the problem the OP alluded to... if it does.???....OK FUN, I'm going to learn something!  (Really, I enjoy it!)
Message 7 of 8
(12,246 Views)
Because it's meant to concat arrays, not strings. It's true that the same term is used for both, and there's no reason in principle why NI can't make a concat tunnel concat strings as well, but since the code for concatting strings is so easy, I don't see the point. If anything, what's surprising there is that the wire coming out of the tunnel is not broken.
___________________
Message 8 of 8
(12,208 Views)
