memory could not be read
Hi, I just want to know why I cannot install anymore the LabVIEW software.
I always received this error screen below. I hope somebody could help me with this problem.
labview installation error
Message 1 of 9
(3,888 Views)
Hai,
I can't see any picture in your post. Maybe you forgot to attach or my browser problem. Ok comeback to the point. Are you trying LV8.6.1? see this thread.
Message 2 of 9
(3,872 Views)
Hi mathan,
I suppose I have also the same problem. I am installing LabVIEW 8.6.1. I also uninstalled all the national instruments programs in my pc and still I get the same error. I'm still puzzled on how to make this thing work.
Message 3 of 9
(3,858 Views)
Hi renelson_...,
run msiblast after uninstalling the ni products.
Hope it helps.
Mike
Message 4 of 9
(3,854 Views)
This sounds very similar to the threat mathan referenced. Are you installing 8.6 or 8.6.1 and what versions of software did you have on your machine before?  I would definitely keep an eye on that thread and I am going to wait to see what that engineer finds on that issue, but more information is always useful.
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
Message 5 of 9
(3,828 Views)
I have a LabVIEW 8.5 installed before in my pc. Now, I have uninstalled all the National Instruments products to install version 8.6.1
Message 6 of 9
(3,817 Views)
hi mike,
I have tried using the msiblast but I got this error message.
Message 7 of 9
(3,815 Views)
I have already made the installer working.
What I did is I just deleted all the registry values that has a "National Instruments" string in it using the Registry Editor in windows.
Most probably it is the registry entries that are causing the "memory could not be read" error. They might be looking for the particular files that were already uninstalled or deleted.
So by removing the registry entries that looks on the specific path which are already deleted on the hard drive, I saw that the LabVIEW installer just went well.
Thanks for the help guys!
Message 8 of 9
(3,761 Views)
Glad it works out finally.
Thanks a lot for sharing here.
Mathan
Message 9 of 9
(3,759 Views)
