in data 03-10-2009 09:17 PM
Hi, I just want to know why I cannot install anymore the LabVIEW software.
I always received this error screen below. I hope somebody could help me with this problem.
in data 03-11-2009 01:44 AM
Hai,
I can't see any picture in your post. Maybe you forgot to attach or my browser problem. Ok comeback to the point. Are you trying LV8.6.1? see this thread.
in data 03-11-2009 03:11 AM
Hi mathan,
I suppose I have also the same problem. I am installing LabVIEW 8.6.1. I also uninstalled all the national instruments programs in my pc and still I get the same error. I'm still puzzled on how to make this thing work.
in data 03-11-2009 03:15 AM
Hi renelson_...,
run msiblast after uninstalling the ni products.
Hope it helps.
Mike
in data 03-11-2009 03:18 PM
in data 03-11-2009 10:10 PM
I have a LabVIEW 8.5 installed before in my pc. Now, I have uninstalled all the National Instruments products to install version 8.6.1
in data 03-11-2009 10:19 PM
hi mike,
I have tried using the msiblast but I got this error message.
in data 03-16-2009 05:12 AM
I have already made the installer working.
What I did is I just deleted all the registry values that has a "National Instruments" string in it using the Registry Editor in windows.
Most probably it is the registry entries that are causing the "memory could not be read" error. They might be looking for the particular files that were already uninstalled or deleted.
So by removing the registry entries that looks on the specific path which are already deleted on the hard drive, I saw that the LabVIEW installer just went well.
Thanks for the help guys!
in data 03-16-2009 05:16 AM
Glad it works out finally.
Thanks a lot for sharing here.
Mathan
