median filter
Hi  I am studying on filtering
My basic trial is from the txt file with 1D array,  with using median filter tool, resulting median filtered signal
But it doesn't work which means it doesn't indicate on plot. I don't know why even it didn't occured error.
Please let me know the reason.
Message 1 of 8
(5,323 Views)
You show that you are reading three separate files and you did not attach a single one.
Message 2 of 8
(5,311 Views)
yes... other things are working but... last process is not working
Message 3 of 8
(5,301 Views)
So why would you respond and still not attach the data files? Do you really want help? No one here should have to guess. Good luck with it.
Message 4 of 8
(5,288 Views)
this is the data what I asked
Message 5 of 8
(5,272 Views)
Are you really reading the same file in parallel? Once would be enough. You can branch the wire later.
(If you are reading different files, you need to tell us what you are reading where)
Each of your IO trains containing four file IO functions followed by "spreadsheet string to array" could be replaced by a single "Read from spreasdsheet file". try it!
Your files contain only a single column, so you should create a 1D array instead.
Your "reshape array function creates a 1D array with a single element (the original element at (0:0). Filtering a 1D array with one element will not give you any interesting result. It is possible that you want to use "index array" getting the first columns of your 2D array as a 1D array.
Message 6 of 8
(5,246 Views)
Accepted by Strokedrat
Try something like this. Filter seems to work quite well:
(Note that read from spreadsheet file has changed in LabVIEW 2015, thus the red X over the icon. Just ignore that. Make sure to select "transpose" so you get the first column instead of the first row)
Message 7 of 8
(5,229 Views)
Thank you for every thing.  I knew that problem
Message 8 of 8
(5,177 Views)
