measuring pressure using arduino and labview
heyyy guys i been working on my graduation project i need to measure the pressure with mpx5700dp sensor using the arduino board and labview i made this block diagramme where i converted the voltage into pressure using the convertion function and displyed it on the graph it on the graph also i created a thingspeak server to send the the data and stock it there the thing is i'am not sure if my work is correct ... i need someone to cheek it pls before i present it [https://i.stack.imgur.com/QW9xA.png][https://i.stack.imgur.com/QW9xA.png]
(1,140 Views)
Heyyy Michall87 -- why not ask your classmates to look at your Project?  I notice you are linking to "pictures", which are not very helpful for evaluating if the LabVIEW code "works" (it is hard to "run" a picture).  Presumably you have this code on your Laptop (or a desktop) -- drag a buddy over and demo it, asking for suggestions ...
(1,099 Views)
