matlab script node error 1050 LV 8.2
I keep on getting a 1050 error code when  use the matlab script node. The examples do not work either. However, the MathScript Window does seem to work. I am using LV 8.2 and 64 bit Matlab R2006a with 64 Bit Windows XP. I have tried closing and restart everything, doesn't seem to help. Any clues what is going on?
Scott
(2,815 Views)
Hi Scott,
Another thing to try is see if the MATLAB® Script Node is trying to open any files, and make sure that the current MATLAB® directory is set to the directory where the file is located.
LabVIEW 8.20 is not supported on 64-bit Windows XP, so this error may be a result of the incompatibility with your operating system.  For more information on LabVIEW’s compatibility with 64-bit Windows XP, please look here.
If you have any further questions, please do not hesitate to let me know by replying to this post.
Ching P.
DAQ and Academic Hardware R&D
(2,804 Views)
