matlab and Labview executables
I'm trying to build a stand alone labview executable that incorporates matlab code. Ideally I only want to install the runtimes for matlab and labview onto the target PC's (so basically I don't have to give full copies of the software to the clients) so I am trying to get both matlab and LV to build into a single exe file. However this seems to be easier said than done. As a simple experiment I tried building an LV app that incorporates matlab script to an exe, but it will not run (and this is on a PC with matlab installed) - not a promising start! I've also tried building the matlab code to a dll and incorporating this into LV but again it refuses to run - other threads on here suggest similar problems.
So, basically, does anyone have any idea how I can achieve a single standalone application, written in labview that incorporates all my matlab scripts too?
Many thanks
(3,487 Views)
Hi There
You don't mention the software version of LabVIEW you are using.
With older versions there is a KB which explains how to get this working:
http://digital.ni.com/public.nsf/websearch/CCB969868C2946608625673E0077D841?OpenDocument
What actually happens when you try to run the executable? Do you have error handling setup and if so is any error message given?
SimonS
(3,479 Views)
Hi Simon,
I hope you don't mind me jumping in.  I actually have experienced the same problems.  I am using LabVIEW 7.1.1 with MatLAB 7.0.  When I build the application and try to open it up, the LabVIEW rectangle on the task bar shows up, but I cannot maximize or open it.  No error message shows, it just freezes and I must terminate LV.  Th eonly option I have (right click on taskbar) is to close the program- minimize, maximize are all grayed out.  I have attached a very simple program that I attempted to build into an .exe.  Please let me know if you were successful.
Ivanka Slywynska
(3,394 Views)
I have read teh link yo posted and I have tried teh following:
1) put matscript.dll into a file called scripts
2) built .exe a) adding matscript.dll as a support file and b)not doing so as the link advised
Either way, I had no luck with the exe!
(3,387 Views)
