mathscript error
Hello, I am using the book "Hands-On Introduction to LabVIEW for Scientists and Engineers" by John Essick, and in chapter 3 it tells you to type a code into mathscript.  However, I keep getting an error on the last line, saying: Line 17, Column 4: expecting "end", found ''
This is the code I entered, copied straight from the book:
delta_t=1/f_s
start=0
step=delta_t
stop=(N-1)*delta_t
t=start:step:stop
if s==0
     x=A*sin(2*pi*f*t)
else if s==1
     x=A*cos(2*pi*f*t)
else if s==2
     x=linramp(A,A,N)
else if s==3
     x=A*gensignal('square',1/f,stop,step)
else if s==4
     x=4.0*sin(2*pi*100*t)+6.0*cos(2*pi*200*t)
end
What am I doing wrong?!
(3,188 Views)
Accepted by jhauck1
Hello, jhauck
You must finish every "if" statement with "end".
Proper code would be:
if s==0
     x=A*sin(2*pi*f*t)
else
     if s==1
          x=A*cos(2*pi*f*t)
     else
          if s==2
               x=linramp(A,A,N)
          else
              if s==3
              else
                   if s==4
                   end
              end
          end
     end
end
OR you can use "elseif" statement:
if s==0
     x=A*sin(2*pi*f*t)
elseif s==1
     x=A*cos(2*pi*f*t)
elseif s==2
     x=linramp(A,A,N)
elseif s==3
elseif s==4
end
Refer to Matlab documentation: http://www.mathworks.com/help/matlab/ref/if.html
(3,180 Views)
Thank you so much!!
(3,175 Views)
