match pattern: change regular expression search via front panel?
I have an application that I am developing which is making use of Serial VISA.
I am scanning the output of a serial port which is constantly spitting out a long string of data.
Data is being pulled from the string with several combinations of SCAN FROM STRING functions and MATCH PATTERN Functions.
Question:
How can I use a button or TEXT box on the FRONT PANEL that can change the MATCH PATTERN Functions Regular expression?
for example the string may spit out the following:
 Weight\s\s\s\s\s\s\s\s\s\s\s\s-0.00\slb\s\s\s\s\s\s-16\sbits\s+74.40\s\B0F\sCorrected\s\s\s\s\s\s-0.00\slb\s+0.999987\s%\s\r
in this case the serial device is spitting out data in LB.
It could be possible for the device to spit out data in KG ... thus I need to change the REGULAR EXPRESSION.
Thank you for your time
(2,645 Views)
just a quick example.
there are other way of doing this but I think the ComboBox is quite an easy one.
hope this helps 😉
Epictetus
Antoine Chalons
(2,634 Views)
wow
cant get easier than that!
(2,630 Views)
