08-09-2006 02:53 PM
08-10-2006 11:04 AM
08-10-2006 11:09 AM
08-11-2006 08:04 AM
"Did I describe the problem clearly?"
Well, speaking for myself, I am not sure what is the nature of your challenge.
Are you asking us to use the image you provided as input and work form that...
OR
Do you have the data used to produce the graph available and you want to crunch the numbers?
Ben
BTW: I am not sure if I will be able to help with either of those Q's!
08-14-2006 10:41 PM
08-14-2006 11:05 PM
08-15-2006 08:17 AM
08-15-2006 09:31 AM
Dear altenbach,
Thanks a lot for your suggestion. My initial data and my labview programs were attached. ‘light intensity-initial data.txt’ is the initial data file from a camera software. ‘light intensity-initial data.xls’ is an excel file converted from ‘light intensity-initial data.txt’. Unfortunately, I have only labview 6.1. If you modify my program with a higher version, I can not read it. But I can try to read it on my friend’s computer.
No matter if you can help me further more, I would like to thank you for your enthusiasm.
I would also like to thank shoneill and all those who ever think about my problem.
Quanzeng
