mark923
Using daq, how do I wire a relay on the 9481? I want to turn on one relay.
(2,769 Views)
Accepted by topic author Mark923
I'm not sure if you are asking about the physical wiring or the code wiring.
I would start by using Max, testing the On/Off using the test panel, then naming a task for turning on/off that channel.
Then in LabVIEW you can use the DAQmx Drivers to turn that relay on and off, using the task name. ( please tell me you don't plan to use traditional DAQ 🙂
This should get you going in the correct direction.
Mark Ramsdale
(2,764 Views)
