mark points on 3D graph
I need to mark points (by changing the color of the point)on a 3D graph
which the user would select using mouse clicks. How should I implement
this? Should I use both cursor and mouse event handler in my VI?
IS there any similar example code available?
Any helps would be greatly appreciated
Cheers,
Trin
(3,332 Views)
Start reading at reply #7 in this thread.
I would use a seperate plot to handle the highlighted points. Just add the new point and redraw that plot as they go.
The code for that example is all there.
Have fun,
Ben
(3,313 Views)
