06-18-2007 04:19 PM
06-18-2007 04:45 PM
06-18-2007 05:11 PM
06-18-2007 06:11 PM
06-18-2007 07:33 PM
That happens to be the example I modified. If the exampe works as is, make the modifications I described. If you have problems with that, please review the tutorials already mentioned. What you are attempting to do is very basic.
06-18-2007 07:56 PM
06-18-2007 08:11 PM
06-18-2007 09:07 PM - edited 06-18-2007 09:07 PM
Mike,
How many elements of the array do you have defined in the constant? I am guessing there are 9 elements defined, which is too many for the DAQmx write which only needs 8. Resize the border of that constant to see how many are defined. You may have to delete an element out of that constant.
One other thing. I don't think you would need the for loop which is being iterated 5 times. It is just writing the same data 5 times. Notice in Dennis' example in reply 4 that he is using a 2-D array that is being autoindexed at the tunnel of the 4 loop (and no constant wired to the N). His loop will break the 2-D array into 1-D arrays (probably 8 elements) for as many rows (or is it columns?) as there are in the 2-D array.
Message Edited by Ravens Fan on 06-18-2007 10:09 PM
06-19-2007 02:28 PM
06-19-2007 03:22 PM - edited 06-19-2007 03:22 PM
Still haven't taken the LabVIEW turorial yet, huh?![]()
Look at the picture below. It's just a 2D Boolean array constant expanded to show 8 columns and 7 rows. Use your mouse to left click on any element you want to change from True to False or False to True. You click on the increment/decrement buttons of the array to display different columns or rows. If you see an entire row or column that is faintly colored (such as rows 8 and 9 in the image), that means that row or column is not assigned to the array and would not be sent. You need to click on any element in that row or column to assign it to the array.
Message Edited by Dennis Knutson on 06-19-2007 02:22 PM
