how I can start a waveform with a fixed date/time
I'm trying to start my graph with a fixed date/time (00:00:00  21/06/2007), but It starts with 02:00:00 01/01/1904
How I can to solve this problem?
Thank you
vicens
LV7.1 / WinXP
(3,038 Views)
Hi vicens,
this question occurs often in the forum, but I never had to deal with time scales before.
So I made a small example and it seems it's difficult to get proper x-scale labels on charts. With a XY-graph it's working nice... So maybe you can switch to use a XY-graph instead?
(3,032 Views)
The other way is to use the chart's property node to set the time. This is explained in the shipping example called Real Time Chart.
(3,020 Views)
Thanks GerdW,
I've a mixer between waveform graph and XY graph.
I needed to display values while running the time.
Thank you, again.
(3,019 Views)
If you want your graph to display time on the x axis, you have to uncheck the Ignore Time Stamp option. You could also use a property node as I mentioned. You should also use the Get Date/Time in Seconds instead of a time stamp constant. Place this outside the while loop so you get the current time when the VI starts.
(3,010 Views)
