make a window visible and invisible without closing it
just a simple question, how can i make a window (front panel of a sub-VI) invisible while running another VI, without closing the VI as i would need to use its data again from menu selection. Thanks
(3,155 Views)
On the sub-vi front panel right click the icon in the top-right corner and goto 'window appearance' and then 'customise'. You can also do this by "ctrl-i".
Here you will find options to control window pop-up behaviour.
Hope this helps,
Gurdas
Gurdas Sandhu, Ph.D.
ORISE Research Fellow at US EPA
(3,144 Views)
You could set the VI-Property "FrontPanel-State", if you want to do it programatically.
Hope it also helps.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,142 Views)
Thanks Gurdas and Becktho: I actually want to do it programmatically, Becktho: please how do i set the front-panel window property to being invisible. Thanks
Me
(3,137 Views)
Just create a reference to the current vi.
Then use a property-node.
The value can be set using a constant.
Just have a look at the attachment.
Thomas
Using LV8.0
(3,134 Views)
That's exactly what i was looking for, cheers man. It's working now.
Me
(3,125 Views)
