How do you uninstal old IMAQ driver
I am trying to install NI Vision development module on my computer. I have two versions of Labview (6.0.2 & 7.1) on this PC. When I start the install I get an error that an older version of IMAQ vision driver was found. It tells me to remove it and try again. I don't see this driver in the Add/remove window of control panel. I assume it was installed when I installed Labview 6.0.2 (professional).
Is there a simple way to remove just the IMAQ driver, or should I just uninstall Labview 6.0.2 and then re-install it without the IMAQ driver?
Howard Spec
CMC Electronics
Ottawa, Canada
(2,760 Views)
In your Add/Remove programs, there should be a entry saying "National Instruments Software", If you click remove it will list all the NI softwares you have installed. There you should see the Imaq old driver and you can uninstall that alone. Let me know whether you have suceeded.
thanks,
Logic
(2,757 Views)
What you say is true for Labview version 7.1 but not for version 6.0.2. It is the old version of labview with the old IMAQ driver. I need help with removing an IMAQ driver from Labview 6.0.2
(2,751 Views)
