mHz Stopband filter
I need to implement in Labview a stopband filter with a stop band less than 1 Hz. I ask for help in choosing the type of filter and possible guidance on its best use.
Input signal has fs=10kHz. Attached projects (for labview 2014 and 2017) containing the input signal in the form of a constant.
Is it possible with this input signal parameter?
Thank you
(2,592 Views)
Have you tried using the Filter Express VI (Bandstop) or the Equi-Ripple BandStop.vi in the signal processing LabVIEW palette?
sarahmo
(2,536 Views)
Accepted by topic author Aliaksei.Luferau
sarahmo, Thank you for suggestion. But I solved my issue with DFD IIR Notch Peak Design By Q Factor with DFD Filtering combination from Digital Filter Design Toolkit.
(2,489 Views)
