lvrte 2009 error exception
Good Evening, LabView Engineers!
Can anybody help me with this problem: I've installed LabView RunTime Engine (Standard) 2009 on the computer and run Application.exe created with LabView.
Here an exception:
Exception unknown program exception (0xc0000417) in application at address 0x7858c955.
(2,834 Views)
Hi kolan,
with which version did you create the executable you try to start on this computer?
Mike
(2,823 Views)
Hello, Mike! Thanks for reply!
Version of LabView is 2009 with patch f3. Version of LabView Run-Time Engine is 2009 (9.0).
Processor is Amd Geode GX2 with Windows XP SP3 and latest updates and license.
I have no NET Frameworks installed! May here be a problem? I don't want to setup spare libraries which will requery automatic updates, create services on the weak system.
But the one thing is LabView is evaluation version. I'll try to dial to NI distributor and register it today.
I've tried 2 variants: a) install engine and copy exe+ini+conf; b) create installer with RunTime Engine included.
BlockDiagram and Form in 2 variants: a) empty; b) while cycle with a button.
In all cases the exception with the same number and address.
Kolan.
(2,812 Views)
