lvproj launch from explorer error
I'm using LV 10 SP1 32-bit Vista and this has been working OK for a month.
I was doing some project tidying / renaming etc. but when I tried to relaunch by using an explorer window and double clicking the .lvproj file I get the dialog "Windows cannot find 'c:\  (my path)\test.lvproj' I am still able to launch the project correctly form the startup window.
I now also get the same problem with a brand new project!
Any ideas how to make LabVIEW work with the OS properly again?
Al
Message 1 of 9
(4,069 Views)
I think you should have corrupted some of your installation files. Probably repairing LabVIEW or reinstalling can help. But I'm not sure if this is the best way.
Sathish
Message 2 of 9
(4,064 Views)
I was hoping a reinstall / repair wasn't the answer!
Anything else to try?
Message 3 of 9
(4,060 Views)
Hey Al,
you could launch the project from the splash screen as a recently opened document and Save As... create an additional copy in memory. Let me know if this works.
Regards
Andrew George @ NI UK
Message 4 of 9
(4,040 Views)
Hi Andy,
tried that!
I renamed the project and also created a new empty project with the same problem.
Al
Message 5 of 9
(4,038 Views)
Accepted by topic author Al1234
The problem seems to have gone away!
Several restarts of the computer seems to have fixed it. I don't know if that makes it a Vista or LabVIEW problem?
Message 6 of 9
(4,035 Views)
Hi Al,
So you created a new project and dragged and dropped your VI's into it? is it just this project or all projects from now on? if so well I think a repair would be for the best.
Regards
Message 7 of 9
(4,033 Views)
.... VISTA!?
Regards
Message 8 of 9
(4,032 Views)
I've had 4 years regretting ordering a laptop with Vista. But I can't face reinstalling and the hassle of moving back to friendly, stable XP!
Message 9 of 9
(4,029 Views)
