lv 8.6 Locked (No Password)
LabVIEW 8.6 VI Protection option Locked (No Password) is not being saved.
I also tried saving through Invoke Node, and it didn't work. :smileysad:
Is there any work around?
(3,359 Views)
Yes, looks like you found a bug.
As an alternative, maybe it is sufficient to set the VI to run mode (ctrl+m).
(3,325 Views)
This certainly does look like a bug in 8.6  This was reported to R&D (# 128657) for further investigation.  Unfortunately this is something we may just have to deal with, pending a fix, so take a look at altenbach's suggestion which may suffice as a workaround.
Cheers,
Brian A.
(3,283 Views)
Hi there
I ported from 8.5.1 to 8.6.1. All VIs in the project are password protected. Some of them are opened in Run Mode, some in Edit Mode. The option "Environment->Open VIs in Run Mode" shows no effect, neither FALSE nor TRUE.
<edit>
When i open the BD of a VI that was opened in Run Mode and switch back to the FP the VI is then in Edit mode. This is extremly annoying.
</edit>
Message Edited by chrisger on 06-25-2009 01:04 AM
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,018 Views)
If you press CTRL-M like altenback mentioned, does it go back to run mode?
(2,997 Views)
Yes. The funny thing is: The VI behaves like it's in Run-Mode, e.g. the text settings are invisible etc., but the menu says "Change to Run-Mode" (NOT "Change to Edit Mode"). When i press CTRL-M the VI behaves like in Edit-Mode and the menu still reads "Change to Run-Mode".
Same with CTR-E (like stated above)
Best regards
chris
(2,973 Views)
