lv 8.2 grab image
hi guys,
is there any chance that i can load my programming from version 8.2 to version 8?
thanks a lot
Message 11 of 54
(1,997 Views)
Hi reut,
"save to previous" in the file menu??? Smiley Very Happy
Message 12 of 54
(1,988 Views)
hi,
do you mean during the saving process? anyway i am asking after i have the code that i saved in v.8.2 and i want to open it in v.8. and i have no more the version 8.2
thaks
(i couldnt find where is it "save to previous")
Message 13 of 54
(1,983 Views)
Hi reut,
which version of labview do you currently use? If you have labview 8.2 you can open your vi, select File -> save for previous and save it for 8.0.
Mike
Message 14 of 54
(1,978 Views)
Hi reut,
when you use LV8.5 you can "save to previous" to LV8.2 and LV8.0 ( in the file menu...).
When you only have LV8.0 you have a problem Smiley Very Happy and need to say so...
Message 15 of 54
(1,973 Views)
Smiley Sad what will i do??????????? is there anybody good with programming in labview version 8? and maybe can help me with the code that im interst?
im intersting to capture sequences of images (same idea as the function grab and save to avi, or sequnce and save to avi) when there is external trigger that connected to the camera. on real time during the experiment and be able to save the date for process it later on.
thanks
Message 16 of 54
(1,948 Views)
Hi Reut,
Here is an example I've modified and saved for LabVIEW 8.0 to help you started with your application. It implements a grab and save to AVI file, and though it does not implement triggering, you should be able to modify it to do so without too much trouble.
Please let me know how things progress,
~Nate
Message 17 of 54
(1,931 Views)
Hi Nat,
is that grab and save to avi, the same one as the one of the example menu?
thanks,
Reut
Message 18 of 54
(1,921 Views)
Dear Reut,
The example I attached is basically the same as the shipping example. Please note that I forgot to include the IMAQ Dispose VI, and it should be included. It sounds like once you add triggering you will have succeeded in building the application you described earlier in the post. If there are additional specific programming questions in completing your application, please post back.
Best Regards,
~Nate
Message 19 of 54
(1,912 Views)
Thanks Nat
i try to work with this code but one of the files was missed in my computer, so it couldnt work properly. but i start to build my own code and im not sure which trigger to use from the list of trigger options that exist, what are you recomending?
Thanks again
Message 20 of 54
(1,895 Views)
