Wire organization
I've got two questions about wire organization.  I'm sure there's a really simple solution that escapes me, because there were no hits on the search.
1)  Is there a way to quickly organize the wires in a VI?  I can select a number of wires and run the clean-up, but the wires seem to clean each one separately.  Therefore wires can still cross visually with the group.
2) Is there a way to make sure that you don't have wires running behind controls or subVIs?  Wires running underneath a control can make it very difficult to debug a VI.
Thanks in advance,
William
(2,595 Views)
William,
I'm not aware of a "mass" wire cleanup utility.
SteveA
CLD
FPGA/RT/PDA/TP/DSC
(2,589 Views)
I don't think there is a mass wire clean-up feature.  It's one on one basis.
You can select the wire, right click and select "Clean Up wire"...   It will resolve the wires running below sub-vi's, etc.
RayR
(2,568 Views)
