low speed digital analysis
I have an application (production tester) that requires that I sample 6 channels of 100hz data for about 100ms & do a pattern match. I'm looking for an inexpensive USB or serial unit that has Labview drivers. Any suggestions?
(2,488 Views)
Check the data aquisition page.
You can specify digtial/analog, output/input, number of channels... etc
Then it will give you the results you are looking for.
Cory K
(2,477 Views)
