lost all VISA aliases cRIO 9074
Hi again,
I deleted the visa aliases for the cmodules in MAX and they die not come back after complete new Labview install. But I need them to access all the ports on my cmodules.
Rearranging them on the cRIO does not bring them back, delete and update view in MAX does not work. Edit visaconf.ini does not work.
Any other ideas?
cRIO 9074, NI 9870 and 9871
Message 1 of 13
(6,271 Views)
Accepted by topic author Steffen01
make new empty project. Put cRio in and c modules in question. Deploy c modules. Go to MAX, refresh. Alas, aliases are back.
Message 2 of 13
(6,242 Views)
actually it did not work. Next time I deploy the modules, all the aliases disappear.
Re-installed MAX and never VISA, no luck
the bits that say ASRL6::INSTR for instance to be more precise
Message 3 of 13
(6,220 Views)
Hi Steffen01,
I'm not sure of a way to recover NI MAX settings if they were modified and not backed up. Is that a good understanding of your situation? You had VISA aliases set in NI MAX, deleted them, and now want to recover them? You were correct to look at the visaconf.ini file.
To edit them again, you can do that with the VISA Alias Utility in NI MAX. You can read more about NI-VISA Aliases to modify your aliases again. Let me know how that works for you!
Timothy D.
Applications Engineering
Message 4 of 13
(6,207 Views)
Hi Timothy,
I give it a try. Could it be because of Windows 10? I am running Labview 14.0 on a Windows 10 laptop, and seems Windows 10 I need LV15 at least
https://www.ni.com/en/shop/software-portfolio/national-instruments-product-compatibility-for-microso...
Pretty much I migrated from a Windows 7 PC to a Windows 10 Laptop and replaced the Comsoft with a Kunbus profibus module. When I reimage the cRio with the RAD module, the aliases are back. But then I have to redeploy the C modules (9870 and 9871) and the aliases disappear again.
I suppose I better wind it back to Windows 7
cheers,
Steffen
Message 5 of 13
(6,199 Views)
Steffen01,
When you load the cRIO image using the RAD utility, you are setting up the software as you had it before (including the aliases). When you deploy your configuration using LabVIEW, you re-write the way the cRIO is configured. Therefore, I would expect the Aliases to go away when this happens.
How do they look like in NI MAX, under the cRIO's Devices and Interfaces section? Can we have a screenshot? If change the Aliases there do you see changes?
On another note, you are correct. Windows 10 is just supported from LabVIEW 2015 SP1 and upwards.
Let us know your results.
Message 6 of 13
(6,172 Views)
Hi Oscar, I installed Windows 7. For now it seems ok, but I am cautiously optimistic. Things just went worse after complete LV re-install in Windows 10. Cheers, Steffen
Message 7 of 13
(6,169 Views)
Keep us in the loop, Steffen. Thanks for the update.
Message 8 of 13
(6,167 Views)
just where are they stored in the cRIO?
I deployed some modules on a 9035, now the aliases on the 9074 are gone again. Both cRIOs I used the same host PC to set them up. So I suppose each cRIO should have its own host PC and thats it.
https://forums.ni.com/t5/Instrument-Control-GPIB-Serial/multiple-visa-aliases/td-p/1181439
I have to look at this.
Message 9 of 13
(6,138 Views)
this seems to do the trick
Message 10 of 13
(6,106 Views)
