loop will not stop if event structure exists.
@GilMaor wrote:
I have attached one of the subVi.
Have you ever wondered what would change if you would remove the  "equal true" and wire the error boolean directly to the case structure? 😮
(Even better: Note that you can even wire the error wire directly to the case structure to get a Error/No error cases as you do below. Why can't you combine the two case structures into one?).
What is a typical value for the ms multiple? This subVI will terminate after 50 tries anyway, even of stopall is false
If your toplevel VI does not stop as expected, it could also be operator error. For example if you use the "continuous run" button instead of the "run" button, it will immediately restart from the beginning once it completes.
Message 11 of 11
(352 Views)
