looking for a LabVIEW interface for controlling a material test stand
Thank you, gwd, for those VIs.  I am working with an Instron 4201 - is this similar to your machine?
I am using a GPIB to interface the computer with the Instron equipment.  After installing the GPIB, there was sample VI that came from National Instruments with the GPIB, but it did not seem to communicate with the Instron using a basic command.
I think one of my main problems is that I do not know the GPIB address of my Instron machine.  How can I go about getting that?
Message 11 of 15
(1,762 Views)
- look at your manual to see what the commands are, the syntax may well be the same
- if the instrument is like mine the address is set with dipswitches on the back of the control unit. Again, your manual will say.
- I recommend writing a vi to do something very simple (like a reset). Use this to verify that you have communication with the instrument before attempting anything else.
Message 12 of 15
(1,749 Views)
I also have developed and sell commercially software of a materials test. It was originally developed for a generic tensile/compression test platform. send me an e-mail at the following address:avicohena@gmail.com
Message 13 of 15
(1,725 Views)
Hi and sorry I am so late getting in on this conversation. Could you send me a contact email regarding the interfacing to an Instron test frame?
Message 14 of 15
(1,222 Views)
Hello Alex,
I am working with a MTS QTest/25 with a similar issue (old computer and need to be able to run LabVIEW to run tests). How did you go about replacing the old equipment and installing this new software?
Message 15 of 15
(1,042 Views)
