local time to us timezone
Hi to all,
Is it possible to display a different timezone from your local PC? Ex. My PC is set in Philippines timezone but I want to display US timezone during the query. Hope anyone can answer my question. Thanks in advance.
Message 1 of 20
(5,474 Views)
Is this related to LabVIEW?
Can you post a simple VI that shows what code you are working with?
Message 2 of 20
(5,462 Views)
Yes. This is labview related. What I'm trying to do is to display other timezone without changing my current PC timezone. I can easily display my current timezone and local date/time using the Format Date/Time String but I cannot find a function for displaying other timezone (in this case US timezone).
Message 3 of 20
(5,450 Views)
Add or subtract from the timestamp the number of hours different between the two time zones before converting it to a string.
Message 4 of 20
(5,441 Views)
Of course, RavensFan knows that the TimeStamp is in seconds, so if the difference in time zones is +7 hours, you would add 7*60*60 to the local TimeStamp to get the equivalent TimeStamp in the other Time Zone.
Message 5 of 20
(5,431 Views)
And of course both RavensFan AND Bob_Schor understand that the best way to do.math on time values is to use units. By assigning a time unit to all the values, you can add and subtract values without worrying about converting everything to a common unit.
Mike... 😇
Certified LabVIEW Architect
LabVIEW Champion
Message 6 of 20
(5,398 Views)
Thank you guys, for all of your replies. I was able to figure out the initial problem using the attached code. However, I want my final output to be in military (24-hour) time, same as the input format. Any suggestions?
Thanks again.
Message 7 of 20
(5,387 Views)
Hi rctrigger,
wow, a lot of code for a simple add/subtract operation:
You haven't understand that "use a DBL float with unit enabled" thing before?
Then you need to use a proper display format or format string. All the formatting options are explained in the help!
Message 8 of 20
(5,378 Views)
Yeah units are great until they don't work, then they are terrible.  You can achive similar results if you change the display format of the double constant and show it as relative time HH: MM: SS then have the constant have a value of 4:00:00, of course with a comment or a label explaining the format.  This also allows to mix units in relative time and you can subtrac 4 hours 2 minutes with 4:02:00.
Message 9 of 20
(5,337 Views)
Yes, well time calculations are an area where units work really well. For example, you can easily expand on Gerd's example to add any sort of arbitrary time offset:
Mike...
LabVIEW Champion
Message 10 of 20
(5,330 Views)
