load error in LabVIEW communications
Hello Everyone,
I am using LabVIEW Communications System Design suite. I connected USRP 2953R using PCI interface to the laptop. 802.11 WLAN framework is being used for the project. I had to check channel estiomation using antennas and it was done. Today, I am stuck with a load error while opening the project. It is saying that the project includes following featrues thta are not supported in this version of LabVIEW-
LabVIEW FPGA SystemDesigner plugin
USRP SystemDesigner plugin
FlexRIO SystemDesigner plugin
LabVIEW FPGA
I attached a screenshot of it. Please have a look and help me in sorting this.
Best Regards,
Ramya
(3,773 Views)
There may be a chance version difference between existing code and the software packages.....
Whether the project is developed in the same pc/laptop or copied from some other system
(3,722 Views)
What is your current version of labIEW?
(3,683 Views)
The OP stated to be using the LabVIEW Communications System Design Suite
It is not exactly LabVIEW as we know it, but a special build NI made for 5G development.
(3,675 Views)
Hi Everyone,
This was a problem due to communications suite license. I contacted the sales department and they gave me an activation key to extend the license(as I am using the suite on a trial period).  There was a loading error because LabVIEW communications software was loaded instead of Suite which is not suitable for the respective plugins. The issue is resolved when I used the activation key to reinitiate LabVIEW suite. And I thank everyone who tried to help me.
Best Regards,
Ramya
(3,666 Views)
