little endian binary
How can I read a file in LabVIEW written in little endian binary code? Can you tell me where to find the data structure for this binary format?
(3,204 Views)
You have not given me alot to work with here.
THe "open file" node will let you specify a data type for the file. Try array of u8's to start.
THe Advanced>>>Data manipulation pallete has swap bytes swap words, split.....
The U8 can alos be converted to an array of booleans where you could use the "revers 1-d array".
Well those are the tools you will need. If you figure out more about the file format, we may be able to give you a hint as to how to assemble these parts.
Ben
(3,204 Views)
hello Ben thanks a lot
I was able to solve it. It was the swap bytes function that I needed to add, thanks for the tip for locating it
greets
Frank
(3,204 Views)
Glad to help.
Ben
(3,204 Views)
