listbox
Hi Soundarya,
it's completely irrelevant where the value is coming from (list- or combobox), when the problem stays to wire the value to a different vi...
Message 11 of 34
(2,262 Views)
Try this
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 12 of 34
(2,261 Views)
Problem Solved?
Balaji PK (CLA)
Message 13 of 34
(2,240 Views)
is thery any way to unload a VI?
InAdvance Thanks
Regards
Soundarya
Message 14 of 34
(2,230 Views)
Hi Soundarya,
again there is not enough information to give good advice... It depends on context and what you try to achieve!
Short answer:
When the vi is loaded by vi server functions you can also unload it! But you better give more info...
Message 15 of 34
(2,216 Views)
hi,
I have two vi's. In my first VI, i have a button named Cancel. So when i press Cancel, the particular vi should get closed and it should open the second VI?
how can i do this in labview?
InAdvance Thanks
Regards
Soundarya
Message 16 of 34
(2,188 Views)
Go through the Labview Basics 1&2 For programming practices.
Try the attached VIs
Message Edited by Baji on 08-07-2009 11:42 AM
Balaji PK (CLA)
Message 17 of 34
(2,182 Views)
Go to File >> VI Properties >> Window Appearance category >> Customize...
Check the "Close if originally closed" option, you re done. It ll automatically close the first VI when you click the Cancel button, that is (only if) connected to the conditional terminal of the while loop.
Your second VI should be residing inside the case structure that will execute on Cancel=True inside the while loop of the first VI.
I suggest you to rename your Cancel button as 'Close', for easy user-understanding.
Message Edited by parthabe on 08-07-2009 01:14 AM
- Partha ( CLD until Oct 2027 🙂 )
Message 18 of 34
(2,178 Views)
hi,
thanks for your answer. but i have one more query which is related to vi.
so as i already told u that i have one cancel button in one vi. another vi consists of one string control. once i select cancel button, it has to focus to that string control. i mean curson have to be placed in the string control
InAdvance Thanks
Regards
Soundarya
Message 19 of 34
(2,156 Views)
You need to use the Keyfocus property for the Str Ctl, to bring the cursor into it, when your SubVI is opened.
Message 20 of 34
(2,153 Views)
