listbox
hi,
i was able to read the value from the list box.
but i was not able to send to another vi.
how can i do this?
InAdvance Thanks
Regards
Soundarya
Message 1 of 34
(6,128 Views)
What do you mean send to another VI. Do u want to send the list items to some other VI-Then read the Item names property node and send to the VI.Post the code and mention where u having the problem.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 2 of 34
(6,121 Views)
Hi Soundarya,
again you weren't able to stick with your original thread, hence the question of Baji...
As mentioned already: global, FGV, notifier, queue Smiley Sad
Message Edited by GerdW on 07-29-2009 01:00 PM
Message 3 of 34
(6,114 Views)
Try this. I also noticed that you peoples are not stick with the same post(Soundharya and Vipul),Already Mike also commented this. Still u peoples are doing the same. It makes us difficult to track and answer your post.Stick with the same post for quick reply.
Message Edited by Baji on 07-29-2009 04:42 PM
Balaji PK (CLA)
Message 4 of 34
(6,105 Views)
Hi Baji,
i think you better should use the value change event instead of the timeout.
Mike
Message 5 of 34
(6,101 Views)
Hi Soundarya,
Get the Listbox's Itemnames in a Str Arr. Pass this Str Arr & the Listbox variable (either as a Listbox itself or a Numeric I32) into the SubVI (your another vi) thro' the Connector Pane. Inside this VI, use the Index Array primitive to get the value of te Listbox you were able to read in the Main VI. Smiley Happy
Or else, pass (only) a Ref to the Listbox into the SubVI & do everything there itself using generic property nodes (available in Applications pallette) connected to this LB Ref. Smiley Wink
Message Edited by parthabe on 07-29-2009 06:18 AM
- Partha ( CLD until Oct 2027 🙂 )
Message 6 of 34
(6,100 Views)
Sorry I posted the wrong VI mike.
Balaji PK (CLA)
Message 7 of 34
(6,095 Views)
Hi Baji,
Mike
Hi Mike,
Why you quoted Baji's post for your explanation... ?! Smiley WinkSmiley Very Happy
Message 8 of 34
(6,093 Views)
Hi Baji,
Is this a correct VI? Smiley Tongue Smiley Very Happy
Message 9 of 34
(6,091 Views)
hi,
previously i have asked for list box
now its for combo box
Thanks in Advance
Regards
Soundarya
Message 10 of 34
(6,019 Views)
