listbox
How to create a listbox for jpg picture,?so l can choose different picture in listbox ,and the 2d picure control can display.
(3,365 Views)
Hi zychocolate,
use a picture ring…
(3,347 Views)
Accepted by zychocolate
If you are trying to import different pictures at run time you can do this with a 2D picture control and the tools found on the Graphics & Sound >> Graphics Formats subpalette.  Here you provide a path to a picture file and it can load the data which can be displayed.
But if your images don't change at run-time, the easy solution is the one already mentioned.  Import each image into a ring control, then pick which image to display when a number.
(3,312 Views)
