list/verify target(s) in VeriStand using the .net API
Is there a way to get the list of all targets in a setup using the .net API?
I checked the help for 2010 and 2011, nothing.
Alternatively, is there a way to check, if a specific target is present?
(Our goal is to help the user with better diagnostic to setup valid connections to VeriStand
Thanks for your help,
 - AJ
(2,851 Views)
Hi AJ,
Yes, you can use the System Definition API to get a list of all targets in your sysdef, as well as their properties.  You can then use an RT Utility VI to get information about whether a target is up and running.
You can find documentation for the System Definition API in the NI VeriStand 2011 help.
I have attached a simple example of how to do this.  You'll probaly want to add some better error checking to it, but hopefully it gets the idea across.
(2,840 Views)
It has come to my attention that you may not be using LabVIEW, so I have attached a screenshot of the code.  The NI VeriStand .NET API calls will be the same regardless of your calling environment, so you should be able to translate the code below to C++.  The only thing I'm unsure of is how to get the target information from C++. It might be possible to use the System Configuration API to get this information, but I have no experience using it outside of LabVIEW.
(2,830 Views)
sorry, I am in the wrong forum... trying again in the correct one...
 - AJ
(2,825 Views)
