list directory in lastest modified
hi...
does anyone know how to list a directory? I need to list the file names in the latest modified date.
 thanks in advance
Krispiekream
Message 1 of 13
(4,491 Views)
There is a VI called "File/Directory Info" in the File I/O>>Advanced File Function Palette.  I think this will do what you want.
Message 2 of 13
(4,488 Views)
Accepted by krispiekream
I had something like this in mind...
Message Edited by jmcbee on 03-03-2009 01:43 PM
Message 3 of 13
(4,483 Views)
Hi jmc,
why do you use all those conversions? It should work the same without...
Aside from this: nice example!
Message Edited by GerdW on 03-03-2009 09:51 PM
Message 4 of 13
(4,479 Views)
That is a great question, and it does work the same without converting to DBL and back.  I suppose I did it this way because it is the way I have done it in the past, not good justification though!.  Good observation!
Message 5 of 13
(4,475 Views)
A better solution...
Message Edited by jmcbee on 03-03-2009 02:09 PM
Message 6 of 13
(4,473 Views)
thank you very much..!!!
Krispiekream
Message 7 of 13
(4,468 Views)
krispiekream wrote:
hi...
 thanks in advance
For this, you need to Reverse this Sorted Array of Clusters before the For loop with Unbundle node, in the provided example. Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
Message 8 of 13
(4,422 Views)
LabVIEW always give us the possibilities for optimization...
This also should be OK: Only one for-loop and without sorting:
Andrey.
Message Edited by Andrey Dmitriev on 03-04-2009 12:43 PM
Message 9 of 13
(4,418 Views)
But he wants the list of modified files starting from the latest, I think...
Message 10 of 13
(4,411 Views)
