linear slide
What is the easiest way to control a linear slide with LabVIEW?
Would the motor need to be a brushed motor so it could be controlled with a simple PWM circuit, using analog input from LabVIEW compact DAQ to control the speed?
If the device uses an AC motor would I need to use their controller?
metzler CLAD
Message 1 of 9
(3,775 Views)
Hi Metzler,
I suggest to use the controller coming with the motor, independent of brushed or brushless…
Right now I prefer controllers supporting ModBus/TCP protocols.
Message 2 of 9
(3,743 Views)
Sorry, I don't have any experience with motors and drivers. Would LabVIEW then be able to trigger and control the direction of the motor controller?
metzler CLAD
Message 3 of 9
(3,730 Views)
Hi metzler,
Read the manual of those motor drivers to learn about their features…
As long as the motor driver supports those featueres: yes!
Your question is related to hardware features. When you need those features, then your hardware needs to support them…
Message 4 of 9
(3,713 Views)
What type of slide? How do connect the motor? Needed speed?, position accuracy? ... feedback?  force? range?
DIY (cheap? , time consuming, skills? )
Buy ready product with LV driver and support?
Greetings from Germany
Henrik
LV since v3.1
Message 5 of 9
(3,702 Views)
The rest of the story:
I am having an automation company quote a machine.  The machine will have two actuators (possibly electric slides) and one ball screw linear slide,  possibly ESU electric belt driven base slide from PHD (https://www.phdinc.com/product/?product=linear-slides&series=esu).
I need to make sure the LabVIEW can control the driver, at minimum control start and stop, and direction, assuming speed will be able to be one time programmed using ethernet or some other kind of communication to the driver - I am not planning on a permanent ethernet connection.
If this isn't feasible, could I use the Ethernet/IP driver / toolkit for control? If I need to use Ethernet/IP, please point me in a direction to learn about it.
metzler CLAD
Message 6 of 9
(3,693 Views)
What not to buy...
Spoiler
I have a customer that own a bunch of SCN5 actuators that they use for fatigue testing. They are fine if you just want to move from location 1 to location 2 and possibly start and stop the motion via a DO line from a LV app or a PLC. But in my case they wanted to change the motion based on the measurements acquired while testing a sample. And they needed to cycle quickly. Well those devise do talk RS-485 but they default to 9600 baud and there is nothing fast about 9600 baud. The baud rate can be changed but it has to be done via serial commands. Top that off with them having a mind of their own as to which baud rate they will talk at then add in the complicated "swing cat over your head" phase of the moon followed by a power cycle to realize the baud rate change. What should have been a one day effort at best turned into a week worth of poking and prodding to finally get it right.
So unless you are looking for trouble or do not need to control the motion dynamically, look elsewhere and your life will be more peaceful.
Ben
Message 7 of 9
(3,686 Views)
Once the speed is set, it will not need to be changed.  The stroke will be 36", and will need to move in 2" increments.  Again, the 2" increments will not need to be changed.  Does this qualify as not controlling the device dynamically?  The SCN5 does sound similar to the actuator I was considering.
What kind of device would be better?
metzler CLAD
Message 8 of 9
(3,671 Views)
Then I suggest you look into those yourself.
They do support preprogrammed positions and expose digital control where 24V signals can select the desired position. I cannot say much more since my challenge was not that easy.
Ben
Message 9 of 9
(3,669 Views)
