linear fit
Hi Gquadro,
@Gquadro wrote:
but i can't connect my array with ptbypt data queue
Maybe because PtByPt-DataQueue expects scalar values?!
When you already have your data as a 1D array then you could use a loop (without autoindexing) and ArraySubset to read subsets of 60 elements: basic array handling as taught in the Training resources. Did I mention the Training resources before?
Message 21 of 22
(482 Views)
@Gquadro wrote:
Could you help me with this part?
There is a ptbypt version of array min&max, so use that. Note that the first slope is NaN (because we only have 1 value!), so you need to initalize on the second iteration. Also note that you might want to ignore the first results, because they don't rely on a full set of values, so initialize min&max if e.g. i=59 or similar.
This will give you the slope, not the "angle", so add a little trigonometry. I trust you can do that.
@Gquadro wrote:
Then I would like to write these values (max and min) in an external file.
There are millions of ways to write two values to a file. What have you tried?
Message 22 of 22
(460 Views)
