linear fit
At the end I want to obtain an array with the value of the slope and then with max min function I will isolate that values
Message 11 of 22
(1,926 Views)
What's the meaning of "isolate"? Just the get the max and min value?
Message 12 of 22
(1,925 Views)
Yes, yes I need before all the values of the slope and then only the max and the minimum values of the slope
Message 13 of 22
(1,923 Views)
"array min&max" will do that for you. Have you tried?
(Of course a good programmer will not need to keep all values first just to only keep the min&max at the end. One would do a running min/max. The memory requirements will be N times lower.)
Message 14 of 22
(1,913 Views)
Could you help me with this part?
Then I would like to write these values (max and min) in an external file.
Message 15 of 22
(1,906 Views)
Hi all,
Attached you can find my .vi
I have two 1D arrays called "x" and "y".
I need to do a linear regression of 60 elements per time and determine the maximum and the minimum angular coefficient of the straight line.
The linear regression has to be done as follow:
1) linear regression for the data from #0 to #59, save the angular coefficient in a new array called "CA" in the position (0,0)
2) linear regression for the data from #1 to #60, save the angular coefficient  in the array "CA" in the position (1,0)
3) linear regression for the data from #2 to #61, save the angular coefficient  in the array "CA" in the position (2,0)
... till the end of the data into the 1D arrays.
Please Help ME
Message 16 of 22
(1,905 Views)
Hi Gquadro,
what's the point to start a new thread for the very same topic?
Use the PtByPt-DataQueue with a length of 60…
Message 17 of 22
(1,897 Views)
could you show me how to do?
Message 18 of 22
(1,892 Views)
Sure:
Message 19 of 22
(1,887 Views)
but i can't connect my array with ptbypt data queue
Message 20 of 22
(1,884 Views)
