lighting system of five leds
hey, Im  facing a problem in lighting the five leds one after the other in a 0.5 sec delay. I have a true input to the loop containing the leds to let it work continueously,Can someone please help me find a way to fix this problem?
my file is attached here.
thanks
(2,476 Views)
Accepted by Abook7
You weve close.  her is a snippet showing corrected behavior for cluster 2.  You reall do'nt need to recreate the entire array for each itterarion.  I also moved the stop button to allow you to exit faster without waiting for the for loop to compleat all cycles.
Keep reading the help file!
"Should be" isn't "Is" -Jay
(2,463 Views)
Kudos and Accepted as Solution are welcome!
(2,456 Views)
Why the OR function?  You are feeding in an array of 5 false values.  You OR that with something else, you are going to get the other wire.  ORing with a false array doesn't do anything.  (other than possibly limiting the array to 5 elements, but an array subset would do that for you.)
(2,454 Views)
