light intensity range from labview
I have been using the "light meter" module to measure the light intensity from a camera. I found out the range is from 2 to 260. I wonder if there is a way to maximize the range? Say increase to 300 from 260?
(3,410 Views)
Hmm, might the max be 256?  As in 8-bit binary?
(3,378 Views)
Accepted by AlexZLee
While I'm with Bob .. about the U8 light value ...
to increase the value range just multiply with a gain factor 🙂
gain=($desired_max_value)/($actual_max_value)   ( = 300/255 ??)
However the resolution is still U8  😄
Greetings from Germany
Henrik
LV since v3.1
(3,346 Views)
Hi Bob,
Yeah! It is an 8bit image so it is 256. It now makes sense to me.
(3,314 Views)
Thanks Henrik! That's a good idea. Since the grey intensity shows two more digit after the decimal, it would at least look nice when multiple a big number.
(3,313 Views)
