libnipalu.so failed to initialize
centos 7 64bit, first, use ./INSTALL to install lv2017pro-linux, then use ./INSTALL to install NI-VISA-17.0.0 when run visa function in labview , tips " libnipalu.so failed to initialize Perhaps you need to run updateNIDrivers Aborted (core dumped) " , the labview auto quit . what should i do to correct this ? // cmd line root@localhost bin]# visaconf libnipalu.so failed to initialize Perhaps you need to run updateNIDrivers Aborted (core dumped) [root@localhost bin]# updateNIDrivers Configuring NI-KAL for kernel version 3.10.0-1127.19.1.el7.x86_64... Building module nikal... nikal: CC [M] /var/lib/nikal/3.10.0-1127.19.1.el7.x86_64/nikal/nikal.o nikal: /var/lib/nikal/3.10.0-1127.19.1.el7.x86_64/nikal/nikal.c:2043:10: error: ‘GENL_ID_GENERATE’ undeclared here (not in a function) nikal: .id = GENL_ID_GENERATE, nikal: ^ nikal: /var/lib/nikal/3.10.0-1127.19.1.el7.x86_64/nikal/nikal.c: In function ‘nNIKAL100_initDriver’: nikal: /var/lib/nikal/3.10.0-1127.19.1.el7.x86_64/nikal/nikal.c:2083:4: error: implicit declaration of function ‘genl_register_family_with_ops’ [-Werror=implicit-function-declaration] nikal: if ((status = genl_register_family_with_ops(&nikal_netlink_family, nikal_netlink_ops, 1))) return status; nikal: ^ nikal: /var/lib/nikal/3.10.0-1127.19.1.el7.x86_64/nikal/nikal.c: In function ‘nNIKAL240_do_munmap’: nikal: /var/lib/nikal/3.10.0-1127.19.1.el7.x86_64/nikal/nikal.c:3723:4: error: too few arguments to function ‘do_munmap’ nikal: return do_munmap(mm, addr, len); nikal: ^ nikal: In file included from /var/lib/nikal/3.10.0-1127.19.1.el7.x86_64/nikal/nikal.c:61:0: nikal: include/linux/mm.h:2089:12: note: declared here nikal: extern int do_munmap(struct mm_struct *, unsigned long, size_t, nikal: ^ nikal: cc1: some warnings being treated as errors nikal: make[2]: *** [/var/lib/nikal/3.10.0-1127.19.1.el7.x86_64/nikal/nikal.o] Error 1 nikal: make[1]: *** [_module_/var/lib/nikal/3.10.0-1127.19.1.el7.x86_64/nikal] Error 2 nikal: make: *** [nikal.ko] Error 2 nikal: ERROR: failed to build nikal nikal: ERROR: NI-KAL update failed. nikal: ERROR: make of nikal kernel module failed, not installing kernel module. nikal: ERROR: updateNIDrivers should be called again after fixing the problem. nikal: ERROR: Update of National Instruments drivers failed.
(3,050 Views)
Do you have a question and how does it relate to LabVIEW? (Maybe you can find a better community section and have the moderator move your thread)
(3,043 Views)
how does it relate to LabVIEW?  visa driver can not run properly,  it is not about labview problem ?
(2,995 Views)
Your post is almost impossible to read (No punctuation or sentence structure), but the problem seems to be with a driver under linux, not LabVIEW. Maybe the visa forum might be more appropriate?
(2,967 Views)
centos 7 64bit, first, use ./INSTALL to install lv2017pro-linux, then use ./INSTALL to install NI-VISA-17.0.0 , when run visa function in labview , tips " libnipalu.so failed to initialize Perhaps you need to run updateNIDrivers Aborted (core dumped) " , the labview auto quit . what should i do to correct this ?
(2,951 Views)
i post it agian and need your help
(2,922 Views)
Good luck. Hopefully somebody reads this and can guess what's wrong. I cannot help you with this.
(2,915 Views)
