laplace transform
Hello:
I like laplace transform function that is available with labview. I have 500 dicrete data with 1 to 500 sample index. According to the function I can plug in 1D data and end time. What does the out put mean.
1. what does laplace transform real ( not in base package) mean?
2. the output laplace{X} mean what? how can I take those data in real and imaginary axis
3. why I am using discret value for calculating analog laplace transform
4. How can Get transfer function from laplace {X} output.
5. How can plot pole zero from the out put of data.
Pleasse let me know as soon as possible.
I am keenly waiting form your reply.
Best wishes
Moin
Moin
(3,977 Views)
A lot is explained in the online help.
You can also open the VI and inspect the code. It's all plain G, no dlls etc. If you need complex output, maybe you can use it as a template to make your own version.
(3,967 Views)
