lan or network spy
Dear friends;
I want to spy from network with defined IP and port number (my network protocol is TCP/IP) and I want to show spyed data as text.
please help me, how I can do it?
thanks
Message 1 of 9
(3,465 Views)
Are you gonna do this with LabVIEW?
If you're an IT/network administrator and there are some policies that tell your users that they are under suveilance on your network, I could tell you some tricks. But it has nothing to do with LabVIEW, so I don't think it would be propriate to give links to other sites on this topic. It also almost crosses the border on what is legal or not.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 2 of 9
(3,462 Views)
Maybe I misunderstood? Do you want to see the traffic from for example an instrument that is connected to your computer through the network? Or is it like seeing other peoples traffic on the LAN/WAN?
Even
Topro AS
Norway
Message 3 of 9
(3,458 Views)
Search for "Wireshark" and/or "Ethereal".
Message 4 of 9
(3,451 Views)
and this could help
http://forums.ni.com/t5/LabVIEW/WinPCAP-for-LabView-v-0-1-alpha/td-p/343479
Mike
Message 5 of 9
(3,447 Views)
I did this on Linux once. With ethereal and man-in-the-middle. It should be used with care though.
Even
Topro AS
Norway
Message 6 of 9
(3,443 Views)
you assume that we have unknown network that send some data to IP:192.168.0.1 & port:5000 and I want to connect to this IP & port and read these data as string (text) and I get some information from these string. (i.e. I want to discover meaning of these data.) for example I must send command to this network for connect to it and then I read data from it or write data to it during run of my software and application.
Message 7 of 9
(3,436 Views)
Maybe the  The portlistener can help you listen to the port. Atleast so you can read some data and check the port you want. Unfortunately I don't know som much about how to use LabVIEW to do this.
Even
Topro AS
Norway
Message 8 of 9
(3,429 Views)
Hi javadi_ali,
if your are part of the connection as a client, then please see the examples in the example finder, for how you can connect to a server.
Sorry, i thought you would like to get the data from an existing connection, because you have used the word "spy".
Mike
Message 9 of 9
(3,426 Views)
