06-19-2020 08:06 AM
"this method call node could not find its target .The target may have been moved ,deleted ,or rename .Target Name :Basic multitone.gvi"
hello I am getting used to Labview, I have some errors encountered during the modulation process, is there any way to fix this error?
06-19-2020 08:09 AM
Hi John,
It seems you are using LabVIEW NXG, so please indicate that as explained when you start a thread.
Probably there is a way to fix this error - but as you don't supply any code we cannot help you to fix it…
General hint: use a more descriptive thread title. This whole forum is about LabVIEW (not the spelling!), so you could have used "NXG method call problem" instead…
06-19-2020 09:45 AM
Can you give me gmail?can i ask you for help
06-19-2020 09:59 AM
We much prefer to answer things in the forum, as this allows for other people to learn along with you.
