labview
No.  I think the RGT became available with less expensive LabVIEW suites as of  2015.
Message 31 of 51
(2,223 Views)
http://www.ni.com/labview/buy/
You can scroll down to Report Generation for MS Office to see it's still only Pro.  (Suites include pro if they have the DS instead of one of the packs).
Prior to 2014, it was an addon you had to install separately.  In 2014, it installs with LV and includes a trial period for all non-pro users.  It activates for pro.
It's not a big deal.  It's just pointing out if we're seeing it's 2015 (and not pro), we can't simply state they certainly have access to the RGT.
Message 32 of 51
(2,218 Views)
You are probably right.  I thought I had read in the forums, a few times, that it was now more available to LabVIEW users.  I'll have to find it to see if I'm remembering correctly.
EDIT:
http://forums.ni.com/t5/LabVIEW/Convert-text-file-to-excel-file/m-p/3295352#M963559
http://forums.ni.com/t5/LabVIEW/Excel-Format-cells-and-content-via-LabView-possible/m-p/3265628#M952...
http://forums.ni.com/t5/LabVIEW/excel/m-p/3282282#M959013
Now these are all Bob Schor posts.  So the reinforcement of the idea might actually just be based on a single source.  If I could find another source to confirm this, I'd be happy.
Message 33 of 51
(2,211 Views)
I recall learning that the RGT was included in LabVIEW 2015.  I assumed that meant "for all versions".  My apologies if this was only for LabVIEW Professional -- this is the first time this detail has been mentioned (that I know of) on the Forums.
Message 34 of 51
(2,200 Views)
He's likely just making the assumption that most have Pro or a DS or misunderstood the change in 2014.  It's pretty clear on the LV page the RGT is an addon for full/base (does anyone actually have base?)
It's not a huge deal.  It's just not something we should be telling people they definitely have when it's not entirely accurate.
Message 35 of 51
(2,198 Views)
Hello Bob,
Is this the example that you told me about ,if yes could you please send me the vi because i couldn t find the components ?
Message 36 of 51
(2,172 Views)
@Maroua wrote:
Hello Bob,
What you see in the screenshot is a snippet ( http://www.ni.com/tutorial/9330/en/ ). It is a png file which also include the VI itself. Save the picture to your PC, and drag&drop into an empty LabVIEW block diagram to get the VI.
edit: after proceeding as I wrote above, and LV tells you cannot find the RGT subVIs, then you do not have the RG toolkit. What LV version do you use (Full, Pro, version?)?
Message 37 of 51
(2,160 Views)
Yes Thanks Labview (32 bits)   2015 mon pc c est( 64 bits)
Message 38 of 51
(2,152 Views)
Base, Full, Pro ? Which one? Do you have access to RGT?
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209050
If you have LabVIEW Pro version, it comes free. I guess otherwise you have to pay for it...
edit: I do not know whether it is the language barrier or something else, but it takes forever to succesfully change info with you. You might try the French speaking forum:
http://forums.ni.com/t5/Discussions-au-sujet-de-NI/bd-p/4171
Message 39 of 51
(2,149 Views)
ok,is this The toolkit RGT you re talking about?
Message 40 of 51
(2,143 Views)
