labview
Hello ,
Please How can I transfer a cluster(formed of numeric tables) in labview to excel
Message 1 of 51
(7,189 Views)
Hi Maroua,
You can use the "unbundle" or "unbundle by name" function and then wire them into the "Write to spreadsheet file" function. Excel can then open the spreadsheet you make. If you need a bit more help with this let me know
Dan
Daniel Harryman MEng
CLA, CPI
Message 2 of 51
(7,179 Views)
Yes please could you show me an example or explain it to me how can i do this?
Message 3 of 51
(7,171 Views)
Hi Maroua,
Something like this. Unbundle lets you access each cluster element individually. You can then wire each one to the write to spreadsheet file, or build them into an array to use the 2D input of the write to Spreadsheet file function.
Dan
CLA, CPI
Message 4 of 51
(7,164 Views)
Hi DanHarryman,i executed this program but i don t know why when i go to the path that i precised before execution i don t find my tables there?
Message 5 of 51
(7,156 Views)
Hi Maroua,
Try giving the file a name. So if the normal path is
"\...\desktop"
Instead put in "\..\desktop\file.csv"
CLA, CPI
Message 6 of 51
(7,152 Views)
here s what i found in the vi write into spread sheet
Message 7 of 51
(7,150 Views)
and this
Message 8 of 51
(7,144 Views)
Is there any data in your clusters? or are they uninitialised values?
CLA, CPI
Message 9 of 51
(7,140 Views)
Here is my front panel,it contains numerics
Message 10 of 51
(7,135 Views)
