labview update and modules
Hello all,
I have an old Labview version and I need to update it.
During the update I need to choose toolkits, modules (and add-ons?) I need to install also.
However I have a huge VI with lots of sub-VIs and I dont know which toolkits and modules I need to install for it.
Can I find easily which modules my VIs use?
Thank you so much
Orit
(2,680 Views)
The easiest way I found to do this is to install LabVIEW. Once installed try to open the project\VI file. When the software is loading you will get errors for missing vi's and DLL's. Write them down and look them up on NI.com to figure out what tool kits you are using. I usually install one and try again until I stop getting errors.
Tim
GHSP
(2,670 Views)
