01-29-2020 03:39 AM
Hi. i'm facing a strange behaviour in a target PC:
previously I had a lot of labview applications installed in this PC that I removed (and every NI runtime)
The PC is now cleaned out, I'm deploying an installer developped with LV2016+runtime 2016 chosen in the "additional installer" installation project property
Installation is going OK, PC restarted, and a popup appears at clicking on .exe application
"LabVIEW runtime not found
applixation XXXX requires a 2016 version etc etc"
I tested the behaviour of the previous applications I removed by re-installing them on this PC (the installer was not modified) and the problem is persistent.
Can you help me?
01-29-2020 04:14 AM
The same thing happened to me today, but for 2015 SP1. I uninstalled everything NI from the control panel, restarted the PC an installed my application using that application's installer (which included the runtime), and then it worked.
I suspect that the cause for the error was when I installed an earlier version of my application, that perhaps had another version of the LV15 runtime, and there was some conflict there. Uninstalling applications never help, only cleaning out NI software as described above.
01-29-2020 10:08 AM
hi
that's what I did: removing every NI software/runtime and restart, and I still can't
I tested it from different Labview hosting computers, to different target, and every time, the same target PC completes install correctly but can't find the runtime when clicking.
I've noticed the uninstall option from windows10 control panel returns a error popup at openning, while the uninstall option from windows 7 control panel is accessable. Is it a clue?
someone can help?
